leonskibeat
- Joined
- May 8, 2008
- Messages
- 4
These are some images, a description and questions of my first project converting a 100w H3 torch case to HID.
Hello CPF members, I'm a new member, and after having been interested in the concept of car HID technology for a number of years, I always wanted to own a portable version. Never thought that these were available until I did a bit of Google research recently. I was then a little surprised about the cost of buying these things! I guess some of the best models I found (general consumer - not military standard!) were the likes of the Polarian PH50 which I believe are selling for around £1000.
After a little more research, I quickly came across this site, and was inspired. So, I decided to do my own conversion and utilise HID power and efficiency within a torch housing. The existing 100w torch only ran for around twenty minutes. Through the conversion, I've managed to double that time and achieved a higher lumen output, which really does seem much, much higher to me.
After the initial conversion, I took the lamp to a cliff top at night, and was really surprised to see how well it lit the sea below. Subsequently, I've adjusted the beam to a much tighter focus, although not yet perfect, the spot/throw is incredible! the heat can be felt from some distance. I can't wait to take the torch back to the same cliff to see the difference and take some pictures/videos. I'll publish them here soon if anyone is interested.
The torch cost me £18, and the HID ballast/bulb around £40 - so £58 in total. I'm sure it's not the same as the Polarian!, however, a great step in the right direction for the cost.
I'd like to evolve the project in a number of ways...
• Construct a rig to hold the bulb and adjust it with higher accuracy in order to tune to focus
• Install a battery voltage indicator to provide a warning, as I've heard the ballast/bulbs don't like the power to go too low - is this significantly true?
• Find better batteries that last longer (more mAH)
• Ultimately, find a higher power ballast and bulb, perhaps together with a reflector that makes the most of the arc (optimal).
If anyone can advise on the above, or has more improvement ideas, please please comment!
Many thanks! :twothumbs
