jki
I see quite a few posts where people say that the thermal management in their flashlight must be good, because their flashlight gets hot on high output. This is not an accurate statement!
If your flashlight gets hot, then it is also very hot inside. Not good. If there is a good thermal path (low thermal resistance) between the inside and the outside of the flashlight, then the difference in temperature inside-to-outside is maintained at a lower delta.
Take two flashlights, one with excellent thermal path from inside to outside, and one with a poor thermal path. Let's say they both run hot to the touch on the outside. All this means is that the poorly designed light is running hotter on the inside. (For simplification, I am ignoring the ability of the outside of the flashlight to get rid of heat to the surrounding environment, be it to the user's hand (conduction), or to surrounding air (convection/radiation). The ability to remove heat externally is also important, but not necessary for this discussion).
A well-designed flashlight should minimize heat generation to begin with. This includes use of high efficiency LEDs (high lumens/watt) and high efficiency regulation. (Achieving high efficiency in regulation is made more difficult if a wide range of battery voltage inputs must be accomodated).
If high efficiency can be achieved in converting DC to light, then add in good heatsinking and a low thermal resistance to the outside of the flashlight, the flashlight will run cooler, not hotter.
A couple of flashlights that I have that achieve a high level of efficiency include the Fenix P1-CE-Q2, and the Lumapower MRV. Both of these can run flat out and only get warm; never hot. Hot is not good!
