kristiancyclist
- Joined
- Oct 21, 2008
- Messages
- 42
Hi,
My name is Boris and I commute to work on my bike quite a bit - more so this year than other years thanks in part to the high price of gasoline. Gasoline is just not something I want to spend money on and I also don't like driving. Normally I would call this time of year the end of my riding season and only ride on the weekends in the afternoon. Since I am on a good rhythm here, I will continue riding my bike to work.
I know that I will need some sort of lighting system for my bike. The small LED lights that mount on handlebars give a relatively bleak output. They look like something "to be seen" rather than help "to see". I had a chance to check out some of the pricier CygoLite and Niterider systems. Some of these systems cost over $120. It's quite a chunk of change and in some ways I don't mind spending it if I felt that it was worth it but the output was still pretty minimal.
Feeling brave and adventurous, I decided to build my own lighting system. I didn't know where to start so I took at stab at buying some mini fog lights from Walmart. The lights I got are made my Optronics and cost around $15. Two fixtures are include and each fixture has a 50W MR16 bulb. The output was very bright but the fixture got too hot too quickly and I knew that the current draw will kill any practical battery I could take with me.
By chance, I stumbled upon some LED based MR16 bulbs on eBay. Little didn I know that these bulbs are pretty common and I knew even less that LED lights are seemingly taking the world by storm. I got two bulbs: a 15 degree spot and a wider 45 degree sort-of-a-flood. Both bulbs were purchased from LED Wholesaler's eBay store. The folks running the place seem like nice people and were happy to answer my questions over the telephone.
The bulbs fit in the fixtures with some difficultly. In one case I had to use the included rubber washers to push the bulb forward against the front cap and in another and in the other case, I had to trim the internal cup metal that holds the ceramic MR16 base because the bulb was too tall.
I mounted both fixtures on my front rack. Here is what it looks like.
The output of these bulbs is absolutely amazing! I set up a little experiment in my backyard. Three buckets were placed 33 feet away and another three buckets were place 50 feet away. They were lit up as if it were broad daylight.
I don't know if I am approaching a "stuipid bright" level here but I know that I will need as much illumination as I can get. The rural roads in my area are pitch black at night. There are no street lights at all. If the moon's out then it's OK but otherwise you can barely see anything.
I have been using my car's battery for these experiments. Batteryspace.com has a neat kit that includes a battery in a water bottle and charger. I ordered the NiMH kit that gives 4500 mA*h. Even though each bulb draws a measured 250 mA, I wanted to have some reserve in case I get a flat and need the extra time to fix it.
I see now that there are many other ways to make a DIY lighting system and I regret that I didn't stumble upon this forum earlier. Now I must finish what I started. I think I'll be OK but waterproofing everything will be somewhat of a challenge. While I don't intend to ride in the snow and hail, I know I will probably get caught in it at least once. This project has been fun so far and I can see how easy it is to become a "light freak". Sounds kind of fun to follow the technology and play with the gadgets.
Once my system is finished, I'll post some more pictures.
-- Boris
-- Boris
