so how would this compare to a mag623? i want to get one if someone will make me one, or maybe i should make it my self..hmmm yours is beautiful
Hello mr.lumen. I have run lights with both the Osram 90W 64458, and the Osram 100W 62138. For both of them, they pulled about 10 amps and stout batteries were needed. But, I used to have one of the older AWR hotdrivers for the 62138. To be honest, while the light was bright and I liked it, I flashed several 62138s, even with the hotdriver. FYI, my hotdriver eventually failed and is no more. The 62138 bulb, rated at 25 hours, is known to be able to take up to about 13.2 volts. Hence, with 12x AA fully charged nimh batteries, it will flash at direct drive. You can direct drive it with 11 AA batteries. Otherwise, you will need some sort of soft start type of switch, like AW's. The good thing about the 62138 is that the light it puts out is a very pleasing white incan beam very unlike today's bright LEDs.
Now, the 64458 is another story. That bulb is rated at 4000 hours. Hence, it can be overdriven much more than the 62138. While its beam is very much more yellow than the 62138, it is still ok in my old eyes. According to lux's test tables, it flashed at about 20.5 volts. I have been running that bulb, along with, as well, 3 other Osram IRC 4000 hour offerings (64432 35W; 64440 50W; and 64447 65W.) My host is a Mag 4D, with boro lens, FM reflector, modified switch, and 5x AW 26500s. (Unfortunately, AW no longer offers the 26500s. Sigh.) As of now, I keep that light at my bedstand with the 64432 35W bulb in it. My sphere shows it to put out about 1750 otf lumens. Runs for about 45 min. It is my bump-in-the-night light where I want to really light things up, mostly outside. In short, I heartily recommend the Osram IRC lights. Even though I mostly have moved over to LEDs, I have yet to find one so far with a beam that is as pleasing as an incan.
Having said all this, if you are interested in hotwires, one of the best persons, if not the very best, here on CPF to follow is Fivemega. I have used his creations quite a bit and cannot say enough nice things about his work.
