Putting a seoul in your mcluxIII is very much like cryhavoc's thread with one exception. the heatsink does not fit the seoul and must be made a little wider. I used a dremel and got lucky on the centering. Then used a copper shim from the shoppe and sanded a little off of the back of the reflector.
Couple of questions on the MCR-20s(seoul). Does the Mcr-20s need a copper shim to focus properly in the older mcluxIII? Does the beam throw better than a standard Mcr-20 with the back sanded? thinking about buying one if I upgrade my other PD and wondering if it is worth it.
love the tint on the VO bin seoul. another bonus is the low is still surprisingly low, and not nearly as green as the UV1J shifts on low
cryhavoc's write-up
http://www.candlepowerforums.com/vb/showthread.php?t=122152
heatsink after a dremel attack
USVOH seoul VS UV1J Lux III
cryhavoc's write-up
