adsl_keeki
- Joined
- Dec 8, 2006
- Messages
- 7
My EagleTac M2C4 arrived last week. It's my first EagleTac and I am pretty satisfied with my purchase. Here are some modifications I have done on her to make it the “Perfect M2C4” for me.:devil:
By reading the post by richardcpf, you can tell the light is controlled by remote sensors. I adjusted the second sensor slightly to increase the separation of the turbo mode. I also noticed you can change the mounting position of the circuit board (counter-clockwise from the original position) to reduce the separation of the strobe mode.:tinfoil:
I also put some markings on the light to tell me what level I am currently at. I also did a 30 minutes water-proof test (see below).
Remove the three screws at the bottom of the head
The circuit
http://img43.imageshack.us/img43/5135/96798577.jpg
The sensor. I solder the sensor back to its original position (approximately) in this picture
http://img42.imageshack.us/img42/8963/57851750.jpg
Unsolder it and move it to the center position.
http://img40.imageshack.us/img40/8866/21814765.jpg
Mount here to reduce the strobe separation. Or doing reverse to increase the separation
http://img196.imageshack.us/img196/7806/35984038.jpg
Now put everything back together
http://img38.imageshack.us/img38/9026/83011038.jpg
I did these markings inspired by nakahoshi
Turbo
http://img36.imageshack.us/img36/4465/96996917.jpg
High
http://img35.imageshack.us/img35/2970/39096582.jpg
Med
http://img188.imageshack.us/img188/6875/32455366.jpg
Low
http://img51.imageshack.us/img51/8485/73864186.jpg
Here are the some washers that I just got in the mail from EagleTac. It solves the waterproof issue of these lights.
http://img43.imageshack.us/img43/1483/48027472.jpg
http://img42.imageshack.us/img42/8859/31870825.jpg
Body tube with the screws and washers. I also tighten the screws at the back of the body tube just to make sure.
http://img40.imageshack.us/img40/6179/96234419.jpg
Waterproof testing in the washroom
http://img39.imageshack.us/img39/9272/75245154.jpg
http://img38.imageshack.us/img38/9176/18529234.jpg
No leakage found after 30 minutes
http://img36.imageshack.us/img36/559/13797705.jpg
:D
The circuit
Turbo
High
Med
Low
:D
