So, I got one of the new Cree L1's about a year ago, and have always loved this light. It has an awesome form factor, great build quality, excellent throw, grippy knurling, perfect UI.
However, for an indoor use/general purpose light or even for use when night hiking it leaves a lot to be desired. It's beam profile is mostly a big strong spot, with very little spill. I like this light a lot and wanted to mod it to be more of a multi-purpose light, so I asked Mudman CJ to put a warm tint LED and a reflector in it.
In our discussions, he indicated that although not driven very hard, you get a lot of output in this light due to the efficient optic - good point. So...why not keep the optic and just add diffusion film? But I did not want a pure spill light (I can use my F04 for that). So what if we just use a diffuser ring with a hole in the middle??
Thus my L1 experiment...
Note: CJ provided rough-cut samples of diffuser film for me to test. If I decide to go with this, he'll use a press and a punch at work for more even and smooth cut. Also, CJ will install the film on the inside of the lens if I decide to go this route. I just placed it temporarily on the surface of the lens for this experiement.
Stock L1, diffuser film full coverage and ring, F04 beam diffuser
L1 stock optic / diffuser film ring installed
diffuser film full coverage installed (left) / F04 beam diffuser installed (right)
L1 stock optic (left) / diffuser film ring installed (right)
Cycle: Stock optic -> diffuser ring -> diffuser full -> F04 beam diffuser
My conclusion is that the diffuser ring is a great alternative to eliminating the optic and going to a reflector for a more multi-purpose beam. Although you definitely lose some thow and a little overall output, it is far less than is lost with either diffuser, and the beam is much more friendly overall in my opinion. And the great thing is - it's easily reversable!
Now CJ can put a Q3 5A in this and make it all the better!
-Rich
-Rich
