Narrowest Cree q5 optics avalible?
gav6280
10 Min from NDAC.
Im going to start my next project. An underwater 1 LED signalling and pointing light, im going for the real light sabre effect.
What is the narrowest beam angle reflector or optic that you can get for the Cree XRE. And where do you buy it from?
Could i then also add an a spheric lens on top of this?
Well as far as i know the aspherical lenses are going to give you the tightest focus they essentially project the Die... thats what they use for those super long throwing flashlights and the reason they throw so far is tight focus and no spill.. not sure how they will work underwater though?
same thinking, a short focused aspheric so You dont add too much length to the light and dont need a big ashperical
should work underwater too
(with the usual problems: "things" illuminated in beam + light gets spread more than in air)
You might add a short tube with a disc (w. smaller hole than the tube) at the front to cut some spill
Maximum diameter for each individual reflector is 20 mm im looking for 6 degrees as the maximum and ideally would like around 2 - 4 degrees.
I want to do a 1 x R2 scuba long range signalling light that is seriously small, like key chain size. Mainly going to be used for attracting surface cover on night dives, not sure what battery's yet maybe something high capacity and recharable but small as possible.
Any ideas for a donor case / housing.
Really want go down to about a Maglite solitaire size ish. 20mm max diameter.
Needs to be virtually bullet proof as will live in my BCD emergency only pocket and get a lot of knocks and bangs etc..
1x IMR16340. The only battery you should be considering IMO, available from AW in the MP.
For a night dive / surface signal use, I would use a color that is more easily seen than white. My suggestion is either cyan (street light green color) or red / orange.
The situation you describe means the most important thing is rugged, simple, shock resistance, and using cells that don't self discharge. IMHO, that means forget R cells and use a primary like a CR123 size or 2 x AA Li enhanced alkaline.
Slight light output droop is not going to be nearly as important as shock resistance, so I would use a resistored setup - skip the driver altogether.
If I were doing this project, I would use a Lux III Red / Orange with a single CR123 cell and a 1 ohm resistor. It is a large die with very low Vf and high current capability - it is even better than the K2 for this application. You can test the R CR123 as well, but it might need 2 ohms.
Photon Fanatic built a special R/O light for me based on some older CNC123 body designs, a buck / boost driver and 2 x 123. (The buck boost aspect was in case I decided to run a Lux V later instead) IIRC it is set for 1 amp. It is VERY visible and with the low Vf runs a heck of a long time. Red / Orange is the same color as a rear tail light and this LED is the only single LED bright enough to run a rear tail light by itself AFAIK.
Even if you decide to go a different path, try bench testing this setup. BTW - wear sunglasses during the test. :crackup:
Amber or red won't work underwater due to water absortion of "warmer" wavelenghts. Best option is 505 nm, we manufacture them for rescue divers working on rivers, dams, harbours...
Javier
Hi Javier - you are right - R/O will not penetrate. I misunderstood and thought the application was a surface signal, not under water.
I would love to do a light with:
DX 1 x R2 on Star
DX 1050ma Driver single mode.
Ledil 3 deg Optic
25500 Rechargeable Lithium Battery 5000mah
Does anyone know of a supplier for these optics?
And any ideas for housing it?
Also does anyone have any idea who makes the best quality quad XRE optic is, cost irrelevant...As right now i have the 6 deg DX one ans it's not great...
Cheers, i already just looked at that, do you think the ledil ones are the best quality?
The hardest task is to figure out what YOU want the beam to be like, and trust me when I say that after you look at 10 beam patterns on the ceiling, it is not so easy to decide.
The nice thing is that none of the optics / reflectors are really that expensive, and a simple bench test can tell a lot quickly. Just buy the 10 best candidates and shine them up - you will have the answer very fast.
