GarageBoy
I don't want to do the brush anodize removal trick and AW's deep tail caps don't look stock. Any cleaner solutions?
+1:shakehead
If your 18650s are unprotected, or (maybe) very short protected ones, you can do the MagRing mod with no ring -- I ran a Mag61 this way for quite a while.Theres GOT to be a way of mimicking the download's foam pad thing without the ring.
Not enough length for 2x18650, that's why download had a Mag ring & 2x18650 kit, need to extend the mag a few mm to fit 2x18650 even without any spring.
The only way to fit 2x18650 & maintain the stock look is to shorten the bottom of the Mag switch, you can shave off a few mm, also shave the top & move the switch up by 2mm or so (Off center switch post but still clicks). I am not sure that's enough, might need to also thin the tail cap bottom from inside just a bit.
It's the size of the bottom end of a C-mag tail spring -- which is enough to know, since the easiest way to make one is to cut down a C-Mag tail spring.With downloads old kit, 2 unprotected 18650s will fit without the "ring" behind the tailcap.All you really need is a small piece of foam, some braided copper wire, a tube to hold the Batts, and a split ring a touch bigger than the inside diameter of the tailcap (please don't ask what size, I have no idea :shrug. I put together one last week to run a 5cell 'numstar bulb.
2xUnprotected 18650 is a bit risky from safely angle.
I have done it as simple as this, its neat and clean. Then you use a spacer to hold the batteries.
Not sure it will help but the batteries fit easy with this spring. Hardware store spring.
