Fallingwater
I used to EDC this flashlight. It was good, but the lack of a low mode quickly became a nuisance, so I replaced it with my current EDC, the NDI.
I still keep the MXDL as my backup EDC in case I lose/break the NDI, but if I had to actually use it the single-mode-only operation would again become a problem.
So I decided to mod it.
I unscrewed the pill:
Then I levered out the circuit board:
And this is the net result (RCR123 cell for scale, and yes, I know it's not really 800mah):
I don't know why that hole is there, it seems all it does is impair heat transfer in the place where it's needed the most. Oh well.
What I need is a multimode driver that will fit in that pill (no, I don't want to upgrade the emitter - I'm happy with the P4).
The light is a twistie, so hyper-multifunctional 20-mode drivers are out of the question. Ideally I'd want a two-mode driver, but since I can't find any I'll settle with a 5-mode without memory, as long as the first two modes are high and low.
I've had a look at the offers on DX, and I've come out with this one and this one.
I think the second driver is more efficient (all that extra circuitry has to count for something), but I'm not sure if it'd fit in the MXDL's small pill. Also the first one seems to deliver higher output from a single LiIon cell.
What do you think?
Oh, and keep in mind that I'm in Italy, so I can't buy from US dealers such as the Sandwich Shoppe as US international shipping (assuming it's even available) tends to be ludicrously expensive.
I need something from either DX or KaiDomain.
What do you think?
