Need bright LED and optic to replace Fibre Optic/ Halogen light source
Offroad'Bent
Palgrave, Ontario Canada
I am looking for a replacement for a large and heavy halogen lamp assembly that provides light for a microscope via a long fibre optic bundle. The bundle's end is a 13mm diameter fitting.
I was thinking that if I could get a bright Cree R2 and a narrow beam optic in there, I could eliminate all the complexity. I would run it off a wired power source too, rather than a battery.
Anybody have any thoughts? Is there a stock 13mm housing/optic I could use? The whole unit doesn't have to be 13mm diameter, just where the LED and optic are.
What would you suggest for a driver and AC transformer?
Thanks in advance.
Re: Need bright LED in 13mm housing to replace Fibre Optic
A further thought- if nobody has an idea for a 13mm diameter optic + housing, how about mounting the emitter and optic just outside and using some sort of 13mm adapter to send the light in?
OK, a different idea- need help here!
How about taking a Cutter optic like this one
http://www.cutter.com.au/proddetail.php?prod=cut183
and trimming it down to fit in the 13mm diameter tube, attaching a Cree R4 and suitable driver on to some sort of board and heat sink?
Is this what I'm looking for in a driver to run off a transformer?
http://www.cutter.com.au/proddetail.php?prod=cut131
I need help with recommendations of a driver and other bits, or even better if someone can do some custom build for hire.
Thanks in advance!
You should use an optical fiber optic designed to focus the light into the end of the fiber bundle, otherwise you are going to lose a lot of lumens.
I have some Carclo optics for that, they are $5 each. Fraen also makes one, too, but I don't have those.
Plymer Optics
look here at their pdf.
this is what you want (I think!):
Single Cell XR-E Concentrator Lens - Part No. 173
Typical Applications:
» Beam insertion into optical fibre bundles
» Beam insertion into edge of lightguides
Plymer Optics
Is this the same as this one at Cutter's site?
http://www.cutter.com.au/proddetail.php?prod=cut191
Could I use it with one of these R2 LEDs on a round single PCB
http://www.cutter.com.au/proddetail.php?prod=cut651
And this Buckpuck driver:
Or this Bucktoot driver?
http://www.cutter.com.au/proddetail.php?prod=cut619
TIA
How many watts does the Halogen bulb have? I doubt about the brightness will be enough. 20Watt Halogen are roughly 500Lumen. And the Cree R2 only makes 220Lumen.
Gruß td
Gruß td
It's a 75W halogen, but the light transfer to the fiberoptic is very inefficient and I doubt 1/2 makes it through. It's also on a dimmer, and full power's not needed. I tried shining my modified PT Apex in the fibreoptic receptacle port, and it was pretty good, and I think it's only 130 lumens, with about 1/2 shining into the lamp.
If you're going to run the LED at above 350mA, you should check out the Xitanium line, also available from LEDSupply.
