I bought a surefire e2d led defender today when I got home and turned it on I noticed there is much more light on one side of the hotspot than the other is this normal or is something wrong with my light thanks for any help
thanks for the help. I tried out two different ones at the store but both where the same way
Is the led or reflector off kilter? Try taking the head off and put it back on?
I think I will use it the way it is I took it outside tonight and it is much less noticeble at longer rage. and it still makes a very good light. thanks very much for the helpWow, 2 different ones with the same issue, from the same store, that's odd. I can only suggest trying another or turn the light over to surefire for them to fix, the latter will take a few weeks though:thumbsdow
I just bought a KX2 head and took it apart to put a XR-E R2 LED in it. From your description, it sounds like the LED isn’t perfectly centered. The way the TIR optic is mounted, it’s unlikely the optic is out of alignment.
I reflowed soldered the new LED on the stock board and when I put it back together, the beam was as you describe. The LED board is held to the head with two hex screws and adhesive, so it really seems unlikely that it would move on its own – that is, it sounds like the LED wasn’t centered perfectly in manufacturing. I centered the LED and now the hotspot is perfect. With the glue removed from the front part of the head that holds the optic, I was also able to get the best focus. Of course I know I was voiding the warranty as soon as I pointed the heat gun at the head.
I agree with ebow86 – call Surefire and talk to them about it if it bothers you.
fourtyounce48, :welcome:I just bought a Surefire E2D Led Defender. When I turned it on I noticed the beam wasn't a perfectly round circle. I check out some review on youtube and every Surefire E2D Led Defender review had a perfectly round spotlight beam. Should I return my flashlight to Surefire or is this normal?
