gt40
I have been trying to cut 20 tpi threads with my new lathe. I am not sure what I am doing wrong. I am using the following gear combo which I got from the Lathemaster site:
tpi: 20
Top inside gear: 72
Top outside gear: 90
Middle inside gear: 45
Middle outside gear: 50
Bottom gear:75
Is this correct? I haven't been able to decypher the factory manual so I am using the gears called for on the lathemaster site.
Here is what I did:
First I turned the rod to .4675. Then I set my compound to 29.5, used a 60 degree cutter perpendicular to the stock. I tapered the edge of the stock slightly where the thread would start. Then I engaged the feed to cut the threads and continued till they were .435 deep. When I compared it to a 1/2"- 20 bolt, the threads don't match.
I am waiting on tooling etc so I made a cutter which is a 60 degree triangle shape. It seems to cut okay. For measuring, I am still waiting for my thread gauge I ordered so I just used the bolt. I don't know what I am doing wrong unless either the cutter I made is too thick or I am using the wrong gear setup. Any suggestions or verification of the correct change gears to use would be appreciated!
tpi: 20
Top inside gear: 72
Bottom gear:75
Here is what I did:
