Sorry to say, but having bought K2s NOW was not a good idea.
Actual technology is DOUBLE !!! efficient!
Means You could have gotten twice the runtime with same output, or more output with more runtime (cree/SSC needs just 1 A to be brighter as the K2 at their 1.5 A), or could use a much smaller batt pack instead.
... just by reading in here (more than a few posts).
Only thing not to critic the K2 for, is heatsinking, as this is not very critical with a light working submerged.
http://theledguy.chainreactionweb.com/index.php?osCsid=da1a4e1af4b3938c58a11a10f05715c0 = Sandwich Shoppe f.e. usually offers ready made heatsinks together with Cree emitters (or together with McR-XR reflectors for cree leds).
Good luck with Your light, but next time wait a few days more for better info.
PS: Sandwich Shoppe offers everything and most parts with enough info to find what to need --> drivers as well
(imho the best way would be a
Shark and one cell less than emitters used --> makes some 1 hour of light at 1 A)
PPS. are these the # 157 optics You mentionned?
http://www.polymer-optics.co.uk/Luxeon Colour Mixer Range.pdf
please, for Your application get whatever, but not such things (best were the largest reflectors from
Sandwich Shoppe (--> focused most), that fit into Your housing ).
Sure, expensive at 1st sight, but You also dont use cheap air supply parts for diving, or?
Except for the focusing, how did You plan to plant the emitters? Is there a three-pieces-heatsink offered?
Im bot sure if this idea can stand the abuse or can be made tight enough for diving (but think with silicone no problem):
Maglite head, heatsink for three or four Cree emitters, Cree P4 + largest reflis fitting into (except Maglite everything available at
Shoppe).
I am totally sure someone able to built himself a dive light is capable of keeping the water out of such a setup.
