chillinn
I'm going to have to redact my last comment up there about 4.2v 10440 and Li-ion and the Maratac Rev. 3. If you care about your Rev. 3 Maratac, don't put Li-ion in there, it will likely lose its modes from heat damage. The Rev.2 was made with different specs, is considered superior by all that have used both, and the copper version has much better heat transfer, so those with Rev.2 that have been running 10440 have had few problems. The Maratac Brass does not transfer heat as well as the Aluminum Maratac (brass head heats up, tube stays cold). Shouldn't be a problem with eneloop, alkaline or L92 Lithium, but is a problem with anything with more juice. Its possible the Maratac Rev. 3 copper can handle the extra heat of Li-ion, but you're risking $40 and invalidating warranty. Apologies to StandardBattery, whom I disagreed with... I'm turned back around now.
One should also note that the Maratac AAA Rev.3 Brass is definitely not machined from naval or admiralty brass. It is probably arsenical machining brass. Probably not an issue if you don't eat it, though I have a feeling, depending on the actual amount of arsenic, its actually illegal to sell in California due to their laws conserning arsenic, which extended to the brass commonly used for keys (but this is my conjecture).
