if you wander over to the County Comm page, there's now a new CR123A based LED Copper Maratac up.
I just placed my order for one and will be updating this post with pics when I get it, my thoughts on the light and its beam, etc. I'll try and answer any questions y'all have
when I get it as best I can and update this post when necessary. (Please be aware I do not have a lux meter or anything like that
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Here's what we do know:
- Cree XM-L T6 (see specs)
- over
three times heavier than AAA Cu Maratac (to be expected due to larger battery bay?)
---- Weight:
94 grams vs.
27 grams (94g = CR123 version; 27g = AAA version-- both weights when empty)
- 3 modes like the old(er) Rev. 1 Maratacs
---- current rev. 2 AAA and AA lights all use TWO modes (as far as I know)
- same
claimed incompatibility with 4.2/3.7 volt cells.
Here's what we would like to know (I can offer more insight hopefully when I receive mine):
- can you swap out the driver to anything like a GDuP?
---- based on my conversations with modders here, the AAA version uses a small pill that isn't really replaceable by anything already made, however, the wider diameter of the CR123A version may open up a few possibilities for driver swaps if needed.
- does it actually have compatibility with 4.2/3.7v cells?
- will it run on LiFePO4 cells?
- does it use PWM? is it noticeable?
- is the Cree XM-L mounted on a plate for easy/easier modding potentially?
- how many will be produced? Is it truly a limited run?
- are its lumens ratings at the emitter or OTF (out the front)?
- will it have enough copper to install tritium vials in?
Specifications (copied and pasted directly from the CountyComm page with minor formatting by me):
Further Reading:
The Maratac AAA "Cu" (CPF)
Maratac AAA Cu Tarnish Progression (CPF)
Maratac AA Cu (copper) (CPF)
