NoNotAgain
However, now that I ordered the TM26 am wondering if I need to buy a charger for the batteries because the batteries can be charged using the TM26. Any opinions on using the TM26 as a charger for batteries instead of buying the PILA charger? Thanks.
The advantage of a separate charger is that you can have one set of cells charging while using the light on the installed set. Secondly you can monitor the charge of each cell instead of the light just indicating total voltage.
I have both the Nitecore I4 and D4 chargers for lithium ion batteries. The D4 allows you to see the charge rate going into each battery and the voltage. As the battery nears full charge the D4 scales back the miliamps to 30-50 miliamps before terminating charging at 4.20 volts. The I4 just flashes a full charge bar.
