kj2
Have emailed right away yesterday, to check if specs will be the same. Hope to receive an answer on Monday.
I'd love to see some side by side comparisons with the XPL and XML2 but haven't anywhere. Closest I found was Eagletacs own claims on one of their lights with the option for either where they are showing approximately 5% more lumens but 17% more throw with the XPL.
Olight tells specs are the same, with this update.
protected LED die a step in the right direction
For longevity purposes and for those who don't want maximum throw. Like everything else that is a matter of preference,,,,,,,,wouldn't be mine!
well it's a production light w/ a long warranty, not a custom. so there
Well!! They still have the M3X Javelot and M20SX Javelot which are BOTH Domeless,,,,,,,they have that 5 year warranty.
I just got the new XP-L model , it has a different mcpcb and coated led- i measure it at 155kcd and 920 lumen at 30 secs against my thrunite tn32 at 190kcd. Comes with a black and blue lanyard and same specs except the carry case says Customised cree led not XML2 like earlier ones. The tint is nice for a dedomed light [no toxic green] with a very nice defined hotspot . I can notice a few rings in the beam, but not outside in use. In real terms it is a very intense small thrower which throws like the big tn32.
Gday Roberto, i was not going to get this model because of the tint and also i dislike twisties, but im glad i did. First thing its much smaller than i imagined and the tints not like selfbuilts pics, about 5000k temp. This little light really punchs light out there and my original plan was to put a xpg2 s2 1d dedomed in it for max throw -but its so good as it is . At start up on a fresh imr i get 1000+ lmn otf and 165-170 kcd till it settles. I saw the comparo pic with your dd m2x and yours is a cannon - remember not long ago anything with 50kcd was considered a massive thrower- with the m2x-ut it does 50kcd+ on the med level , Martin.That sounds pretty good. I ended up getting mine modded w/ more throw[~300Kcd] and a nicer tint than stock.
Selfbuilt measured ORIGINAL M2X XML2 Domeless @ 196Kcd. Olight measured it @ 164Kcd.
If I had to choose b/w Original M2X and NEW version, I would probably choose NEW version w/ slightly less throw and nicer tint.
Anyone know if this is a better thrower than Vinh's new M25C2vnT?
Not even close.
??? ,,,,,,,,,,XPL W/17% MORE throw??? Don't you mean XML2 w/ 17% more throw?
