outersquare
we are all gona just have to see until someone test both lights, but very anxious to know
there is nothing to test,
there is already a vendor reply that they only changed the spec to match what it already ran at.
Now if they would do the same with the E1B that would ROCK.
My guess is it will happen sometime. The new 1 celled Scoutlight sure looks like a E1B (if you look hard enough)
Yeah, I started a thread about that a few days ago. The M300A Scoutlight looks a lot like an E1B but at 110 lumens. No reason to think the latest batch of E1Bs' couldn't be running the same. But I'll wait for the "official" versions before I decide to get it. And then of course, theres' the LX1 we're all waiting to see...no specs on that either.
If you started with 120 lumens and increased it 60 percent, you would be doing 60% times 120.Yikes....
The old one did 200L OTF.
New one claims 60% increase.
60% x 200 = 120 additional Lumens!!!
By that logic, you could run it off a 17670 and still get over 200 OTF :twothumbs
Where did you get the clip on the Defender ? Is it off one of the newer model Surefires ?
Yes. LX2. With the three clips I have and these three lights, I think this is the best configuration for them. The E2DL is carried much more now that it has the LX2 clip. Otherwise, way too much bezel sticks out for me.
Almost 2 hrs regulation in high beam
Runtimes are shown in the graph, the high level using primary cells was around 2hrs, this is same as claimed by surefire, so I would expect the low beam runtime will close to 47 hrs. I also tested 14650 li-on in high beam (17670 does not fit), has 80% brightness compared to the primary cells, not bad, still very bright.
Sovereign - wondering what method you used to get the clip to fit or anything else to fit it perfectly?
Does the M300A actually have a new emitter, or is just an E1B emitter with revised specs, the same as the E2DL?
