Re: NEW! TerraLUX MaxStar5 K2 5W U bin LED upgrade for 3-6 C or D cell Maglites TLE-6K2!
Well, I received the adapters and after some slight tinkering they work OK. I'm running about 7.3V no load vs. 5.3V no load on my D cells. The incan bulb definitely seemed a little brighter with the new batteries but the LED did not. I guess I really didn't expect it to be since it is regulated (right?). I tried to accomplish two things with the LED upgrade: brighter and longer run-time. I achieved both (I'm assuming on the run-time) but I was really hoping for more brightness, but I not complaining. I did have the light on for a while twice and there was no heat coming off the head or the body of the light although the LED itself was hot. This is my general, check things out, look for things, etc. light so it does not need to be tactical bright, although it is pretty bright and close-range (semi-blinding), it needs to work when I push the button, even several months down the road and it needs to work after I drop it. Time will tell but I think I will use it more often than in the past because of the run-time improvement. Before it seemed like I was replacing batteries more than I was using the light. BTW, Matt, all those batteries I ordered came in handy all ready. I will definitely be ordering again.
