wquiles
Thanks to Barry's recommendation, I picked up this ultra smooth Yuasa RT for my new-to-me knew mill. This thing is so smooth, it is simply unreal:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=200312136375
It is missing one of the lock blocks, so that will be one of my first projects on the knee-mill:
I also needed a chuck for it, and after a month or two looking on Ebay, I bought this one, not knowing for sure that it was:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=360136755935
I was expecting/hoping the chuck to be a good name brand, even a Buck Chuck, but I was not sure. Well, I got it today, and to my surprise, I really got lucky: This is in fact a genuine, heavy duty, old-school Adjust-Tru Buck Chuck !!!.
In fact, one of the links I found tonight, had the cross reference parts for the older chucks vs. the new ones, and it stated that the newer/current 6-jaw chucks from Buck Chuck are in fact cost reduced units, and that these older ones were the heavy duty models!. I never owned a Buck Chuck before, but besides the traditional 4 screws for the "set true" feature, there is only ONE hole for the scroll, unlike my Bison that has 3 of them. The face and jaws show very little wear - not too bad for an "used" chuck.
So I unpack the chuck, and of course find there is no key - I sent the seller an email about it, so I hope to have the original key some time soon. After finding another key that fits "good enough", I found that it is completely tight - I mean the jaws won't move, in or out. I simply can't get nothing to move at all. Of course I am now a little bit scared! Was this thing cheap because it was shot?
I apply a "lot" of liquid wrench and went to do exercise in our treadmill, and when I came back about an hour later, it was still too tight. I first remove the 6 screws that hold the chuck to the mounting plate - but it would not separate - looks as it was welded in place. I hit it will a soft mallet, but nothing. I then tried to remove the set-tru screws, but those were also there tight, and I noticed some rust in those holes - THAT was the key. This thing must have been sitting somewhere un-used for a LONG time. Before selling it, they just cleaned the outside, but inside it was not cleaned.
With WD-40, and lots of patience, going in then out, back in, back out, I finally was able to remove one of the set-tru screws. I then spray LOTS of WD-40 on that hole, and then keep working on the other ones. By the time I got to the 3rd one, guess what? the mounting plate finally fell of on its own!. Looks like the WD-40 finally got things "wet" enough to move against each other to get things loose.
I then put the "temporary" key, try to turn it, but it was still tight. I decided to give it a light "tap", and bam!, it started to move. Just like I suspected, a tiny bit of rust and lack of lubrication was simply keeping everything "glued" together. I then removed the 6 jaws (they come pre-numbered from the factory) - no side-to-side play that I could feel. Basically, besides the dirt and light rust, this chuck is simply tight, and in very good shape. I now have to figure out how to get the two parts of the chuck to separate so that I can really clean and grease the internal parts, before putting everything back together.
Here are some pictures from tonight - still dirty here:
I still have lots of work ahead of me, but to me that chuck is a diamond in the rough (literally!) :thumbsup:
Will
Will
