PP sent for one
OP reflector 2.2A single mode drop-in
Thanks!
I received mine and it has already been a fantastic module. I have used it quite a few hours already this week.
Just to clarify, is the 6v input meant to handle 2 primary cr123a?
Maybe I am being overly cautious but two fresh cr123a are over 6v.
Hi, What kind of regulation/runtime can I expect from a 18650 3100mAh with the 2.8A dropin?
Thanks
PalPal sent: ID7BC196524U964183X
P60 Drop-in (FiveMega COOLY)
XM-L T50 4C 4300K n white
3 level L/M/H Reg - Last Mode Memory
3.5 amps
Smo reflect
$40
P60 Drop-in (for use in C2 + FiveMega COOLY)
90+ Hi CRI Warm White CREE XML
2.8 amps
Smo reflect
$40
+ Priority Mail Int. $15
TOTAL $95
Thanks!!
Christian
3.5 amps
Smo reflect
$40
2.8 amps
Smo reflect
$40
TOTAL $95
Thanks!!
Christian
Thank you, this equation will come in very handy.Divide the amperage into the mah of the battery and you will come close to the runtime. So 3100 divided by 2800
OK I have changed drivers and a few things are different. All modules will come stock at 3 amps. I can reduce if needed but since Cree specs 3 amps these were made stock at 3 amps.
HI
Modules shipped, you may have received two notices of shipment disregard the first one.
thanks
Dave
Would 2.8A high level be able to run in SF C2 in hand for 20-30 minutes or should I reduce it to say ~2.5A?
Never had a high amp drop-in so trying to get an idea for amps vs. heat vs. continuous runtime.
I can't believe I did not notice the low low option. I always pass over 4-5 mode drivers because they tend to have s.o.s. or strobe which I do not like.
My 3 mode is still phenomenal I just like a very low low.
I hope others don't miss this also!
