ZebraLight
We are currently working on a CR123A/RCR123 powered H30 headlamp (will be released in December). Major changes in the H30 include:
- a narrower flood beam, around 75 degree, without hotspot, center area lux reading is about 130% over that of the H50 driven at the same current.
- a recessed lens, as a glare shield plus some protection to the lens
- higher high
- a more traditional clip with narrower gap between the clip and the light
- a lanyard hole on the clip
- shorter than the H50, volume and weight are about the same
- a push button switch for single hand operations
EDIT: several UI designs
(1) soft push button click: OFF, low, med, high, OFF, click while ON for more than a few seconds, OFF
(2) double action push button (like those shutter release buttons on cameras):
light click ---------- low
hard click ----------- high
double light click ---- medium
light click when ON --- OFF
(3) double action push button with momentary:
light press and hold --------- momentary low
further press while mom low - momentary high
hard press and hold --------- momentary high
light click ------------------- constant low
hard click ------------------- constant high
double light click ------------ constant medium
light click when on ---------- off
(4) digital 3 level ramping
press and hold ------------ cycle through low, med and high, release to set
when ON, click to OFF
when ON, press and hold ---cycle through low, med and high, release to set
CAD image:
Any comments?
- higher high
CAD image:
Any comments?
