Mr Happy
I made the mistake of going into Fry's and I saw these on the rack. Couldn't resist:
I'll test them and see how they do.
(Updated 12 May)
Here are some preliminary test results.
The cells are labelled 1.6 V, capacity 1350 mAh minimum.
Size: diameter 14.3 mm, length 50.3 mm. Standard AA size.
Weight: 25 g. About the same as a typical NiMH cell (cf. Eneloop 26 g).
The charger weighs 120 g and has a foldaway plug with no external power cord. It has worldwide voltage input and would be conveniently compact for travelling, dimensions about 115 mm x 68 mm x 38 mm.
It can charge 1-4 AA cells individually (but only 1-2 AAA cells). Charging time is about 1.5 hours according to the manual. That is about right for one or two cells, but may be longer for three or four cells. I have not tested that yet.
I had some trouble getting consistent discharge measurements on the cells, but they seem to agree reasonably well with the quoted 1350 mAh capacity. My problems with consistent discharge measurements might be because the charger is still charging when the green light comes on. To reach full capacity it may be necessary to leave the cells on the charger for a while to finish topping off before removing them.
A family of discharge curves for the same cell tested at different constant resistance loads is shown below.
I estimate the DC internal resistance to be about 25 mΩ, which means you could expect a voltage sag of about 0.025 V per amp of load. On that basis perhaps 5 A would be a reasonable working limit for these cells.
The high working voltage and low voltage sag is going to put a lot of power on tap. Rechargeable alkaline cells these are not.
(Updated 12 May)
