Thanks for the review! Nice work. Any chance you could through up a few pictures of the new QTC. I am curious about how they made the improvements.
Thanks,
eala
As you wish! I cannot get the Gen1 QTC pill out of my lug body Eiger, so the Gen1 pill from my Logan will have to do.
The end that touches the body appears the same in both Gen1 and Gen2
The end that touches the battery, however, is quite different.
The Gen1 Logan pill came with a foam ring to prevent battery rattle - the Gen2 Eiger did not. If we remove the foam ring, we can see that the "ledge" it sat on is completely gone
Top: Gen1 Logan
Bottom: Gen2 Eiger
They've machined a groove into the side of the Delrin pill and slipped a "retaining ring" around it
If I had to hazard some wild guesses as to what has been improved here:
- the QTC material is now round, and the "pocket" now holds it snugly
- the battery terminal is now smaller, which should help focus the compression straight down onto the QTC pill and prevent wobble from side-to-side
- the battery terminal has a small nub on it, which (I believe) would help the battery pivot as the head is twisted down onto it
- the battery terminal is now hexagonal, which "locks" it into place and prevents the rotating battery from also rotating the terminal & QTC
- the retaining ring has a gap which is probably to allow for contraction as you squish it into the body, forming a friction fit. It works ok on mine but I wouldn't say it works better than the old design - a hard shake still sends the pill shooting from the light
Overall though, the changes seem very well thought out and executed. Simple things like a smaller hexagonal battery terminal and a tighter QTC pocket should vastly improve in the usability - and they do.
