kramer5150
Curious... are there any lights that use Nichia 5mm neutral/warm tint LEDs? I can't think of any. Seems like it would be a nice alternative to the angry blues.
:thinking:
:thinking:
This is a beamshot I did that represents the tint of my RS 276-0017 reasonably well IMO:The Radio Shack LED 276-0017 is the best neutral/warm LEDs I have seen. At 5000 hrs driven at 30ma, it is at 100% of initial brightness (this is at 5ma overdrive). It's color is not that **** yellowish color you get with some warmer LEDs, it is more natural. The only problem is that it would require a lens for a tight beam as it has a 30 Degree beam. As with other warmer LEDs, it is not as bright as the cooler ones.
I don't even know if Nichia makes any other LEDs than the angry blue ones.
I know of a Germany based company who sells REAL warm white 5mm LEDs (the best matching incan-color I have ever seen), I modded my SF A2 Aviator with it. The incan and the LEDs have EXACTLY the same color :twothumbs
Timmo.
Edit: The central hotspot is because the LED is mounted in a P60 reflector (from this thread), not a beam characteristic of the LED package itself.
http://www.pur-led.de/index.php?cat=c19_warmwhite-14-000mcd.html325addic:
Would you give us the contact information for obtaining these? It may have been posted at another time, but I couldn't find it.
Thanks...
Connortn
Thanks for the tip, I hadn't thought of that and it's a good idea. However, it's a light that I seldom use anyway and the dim flood is great for close quarters i.e. indoor use w/ night adapted vision.One trick I do to get more light into the reflector is to file the dome down to a couple mm over the die and carefully shape the outer edges to make a low dome LED. Polish with Novus 2 plastic polish or a car paste wax to bring the LED epoxy back clear. I've done this with the GS and the RS LED and it makes a throwier light.
