Nimh charging
ColorMaker
I purchased a charger that charges 20 (10amp cells) for 24 volts. It charges at 4 amps until the delta v is detected then drops to 100ma. There does not appear to be a timer cutoff at this point. Will the batteries be damaged if the charger is not disconnected and left on the charger at 100ma charge rate ?
Jerry
Hello Jerry,
Welcome to CPF.
While it is never a good idea to leave a battery pack on a charger for an extended period of time, you charger will only do minimal damage with extended charging at 100 mA.
Tom
In my experience cells left with trickle charges for extended periods of time, don't seem to hold their charge very well after the fact.
i am on the opposite side, i have never had a (very) slow trickle charge battery not work very well. BUT (isnt there always a but) over much time without a CYCLE, even being trickle charged the whole time , there is voltage depression on discharge , just like it was not cycled, which it wasnt :green:
use it or lose it.
so if i was to provide some "time" factor for leaving it on, it would be the same time factors as for it needing a cycle, and relative to the self discharge and need for a cycle of the battery type. and that isnt an evasive answer, even though its a non-answer.
note: overdischarging a SERIES set for "cycling" the cells in it, is worse than not cycling it at all, so much care would be required to "cycle" a series set.
