jayflash
$20 worth of fairly new Duracell Precharged AA cells were somehow discharged in my Surge and two of them in one compartment split their jackets, vented, spewed electrolyte, partially melted and deformed the battery carrier.
The Surge hangs where I see it frequently, every day and had freshly charged cells installed on 5/30/08 used a few minutes that day and the next with no problem and full brightness. On 6/2/08 I turned the light on only to experience a sickening feeling, knowing the dim beam meant trouble. The switch lever was fully off and beyond the detent which securely keeps the switch off. Had the light somehow turned on, I or my family should have seen it, unless gremlins turned it on over night.
All the cells had been drained with two below one volt and two which were side by side had vented and slightly melted that part of the carrier. I could not find any electrical fault, such as a faulty switch or carrier short. Unless the fault cleared itself, I'm mystified.
The fault had to be common to both, paralleled battery sides. Temporary partial switch fault allowing current through the lamp without actually lighting it?
What would I explain to Princeton Tec or Duracell? Thank you for any help.
