wyager
- Joined
- Feb 10, 2010
- Messages
- 1,114
Oh, man. This was one of the most trying projects I've ever performed, and that's saying something. It shouldn't have been hard. In fact, it wouldn't have been hard, except for that literally everything went wrong that could. :shakehead At first, everything was going great. Perfectly, in fact. I had the XP-G perfectly centered, everything felt fine and it all went together OK. However, much to my chagrin, nothing happened when I put it back together and pushed the button. At this point, I should have been done. About an hour's worth of work.
I spent another two or three hours testing and poking trying to figure out what was wrong. As a last sorry attempt, I tried removing and re-applying the small NPN transistor at the base of the driver board. (At this point, the driver had somehow fallen out of the pill, and I had no idea how to put it back properly.) Success! My test LED lit up. OK! Now, to put it back together. I re-soldered everything, tried to re-center the LED, and tried to stick the driver back in the pill. The driver didn't seem to go in properly, but I ignored it. OK, so with the light all back together, there were a few problems-the LED was WAY off center! I must have gotten lucky before. The driver board was touching the ring, and the device did not click properly. At this point, I sort of forget how it behaved before, but the light did not work properly. Screwing it in all the way made it ramp. Big problem, but at least it worked a bit. So, fast forward to tomorrow (today)-after I got home from school, I basically started over. I took off the LED, cleaned off all the thermal paste I had put on, pulled the driver board off. OK, so far so good. I put it all back together, sanded off the edges of the driver board, and stuck the driver back in. I still needed a way for the driver to stay in place, and nothing had worked so far. Anyway, later that day I bought some super glue. I pushed the driver in as far as I could and glued it. So that's basically where I am now. The LED is a little off center, there is less tactile response than there used to be, and it's not quite 100% reliable when switching. But hey, it works and it's perfectly sun-colored! It's also a lot brighter (but with less throw). It's between standard cool white and the neutral white of my quark. I imagine that with time the mechanism will loosen up and start to function more normally again. Perhaps I can mess with it to make it work better. Anyway, this was a pretty crazy project and I'm glad the thing is working OK. Maybe not 100%, and maybe not worth the effort/money, but it was a learning experience, and now I have a very cool unique light that will probably be fixed completely within the next couple days. Pics!
(old emitter-basically gets auto-centered because of the "cree ring")
tools
new LED
everything apart
pill in vice, ready for new LED
perfectly centered!
This is before it all went wrong. (note-those pictures might be too big, sorry about that. I can't seem to get photobucket to work properly)
OK, this is after repairs. Everything more or less works now.
I left my sweet $300 workbench in idaho when I moved. This is my bedside table.
Anyway, yay! It's basically done! Comments?
tools
new LED
everything apart
perfectly centered!
