Ray_of_Light
Two weeks ago I acquired a new Nitecore D11. I had read about the lack of "shortcuts" to low and high levels, which have been replaced with strobe and SOS modes.
I didn't like the modification to the UI Nitecore made respect to the D10, but I bought it nonetheless. What I deemed of utmost importance is the doubled runtime compared to the D10, due (I believe) to the higher efficiency of the R5 emitter.
I picked up my D11 few minutes ago from the shelves. Turned on, it is very dim. I had placed a Lithium Ultimate AA in it, last week. I measure the battery, it was 0.9 V open circuit.
I placed a freshly recharged white top Duraloop in it, the D11 turns on fine.
At this point, I measured the current through the battery when the light is off. It is a bit difficult, since the D11 uses the piston drive, but I managed to setup the measurement correctly.
Well. I measured 2.4 mA of standby (or parasitic, which is very appropriate in this case) current.
It means that a freshly charged Duraloop lasts around 90 hours, or less than four days, with the light off.
At this point, I sincerely hope that my D11 is defective...
Could any of owners of a Nitecore D11 conduct a measurement of the standby current? So I can realize if my D11 is a single defective light, or all D11 have 2.4 mA of parasitic current draw.
If all D11 draws 2.4 mA from the battery when off, I'll return mine. There is no need whatsoever for a modern circuit to consume so much power on standby. Such behavior makes the light pratically useless; I can't remove the battery everytime I don't use the light.
Thanks
Anthony
Thanks
Anthony
