Nitecore D5 - Piston Drive CR2/14250
ma_sha1
CT, USA
Piston drive used to be exotic & so was CR2/14250 lights,not anymore.
However, I've never seen a light that combined the two together. So I figure it'll be cool to make a mini PD ?
Here is the starting material: A brand new Nitecore D10 R2/HA III Gray.
I first filed away the HAII coating at the tail, it's easier to do it with the whole light. Then, I cut the tail section off. It'll be re-jointed with the top half of the body later on. Hopefully, I'll be able to finish it up this weekend, but for now, I only had time to give it enough damage to send it on to the road of no return:
to be continued...
Re: Piston Drive CR2/14250
Some more progress this morning:
I tape up a Jigsaw to "constant on" & use it to cut just out side the pre-marked line:
Grind it up with a mini grinder to where the line is:
Next, I used a Knife Sharpening stone to smooth up the surface under running water:
Then, open the end up with Step drill bit:
Test to make sure the Piston still fits, this is the half way product:
The "Belly Dancer" :devil:
The "belly dancer" is still a "turn on",:crackup: thanks to the PD mechanism that doesn't need the flashlight body to complete the circuit.
I haven't cut the piston yet, just a sneak preview of what the size of the Mini PD would be. Also need to clean up the cut end a bit more, as I made it 1-2mm longer so I'll have room to clean up the "Cesarean section" wounds.
Stay tuned...
ma_sha1, your stubby mods are great and this is the best one yet!
Thanks, MWClint, very kind of you.
Now, the piston has been cut: Look how tiny the piston is, so cute:D
Finally, a bit flashlight "niptuck" & then applied JBweld & clamp them together.
Now comes to the worst part, I must wait 6-12 hours :(
. . .:whistle: ... :tired: ...:hairpull: ...:banghead: ...:buddies:...
The waiting is the worst part..............When will these be availible for the rest of us??????
Sorry, won't be from me, may be Nitcore could release one at some point?
I don't do custom mod service, only for fun :o
:eek: :eek: :eek:
I had the misconception this thread is going to ask for available CR2 PD lights in the market. Boy, was I wrong.
I saw your "Tribute to Nitecore D10", that was excellent thread!
Imagine if they release a line of "Nitecore D5" in all the various anodizing color finishes?
Dude I'd hate to be the bearer of bad news but I think you've voided your warranty! :crackup: Seriously though. Very nice work there. :thumbsup:
Finally, the 6 hr wait is over. The finished product is only about 3mm(About 1/8 of an inch) taller the Mini Ti,
but so much more advanced than a twisty. Also, to the right, compares to the the full size camo D10.
Beam shot with 14250 on High:
Ma_Sha1
The original spirit of CPF lives on with you..... and you used JBWeld too!!
Ya rule!!! :twothumbs
Thanks for the post, hopefully Nitecore will follow thru with your extensive field research and R&D prototype. :popcorn:
