GarageBoy
I remember that they swapped the converter board and removed the "strong light" stamp. Did runtimes/output/reliability change as well?
How durable are the contacts on the original head? Or, in other words, can I expect them to wear out in the lifetime of the light, considering it doesn't see really heavy use?
Me too! Stupidly endearing; long live the 'Strong Light' NDI's!I actually liked the "strong light" markings and wish they didn't remove those.
I still twist it all the time to change mode...The contacts will not likely wear out on you if you have the older batch considering the light doesnt rely on a twist action to turn it on. On twisty lights that get used alot, im sure they would wear out eventually.
Heres a question, if the newer NDI's have the exact same light engine as the D10, then why wont the light turn on when you screw the head on like the D10 does?
