ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the NiteCore Smart PD D10 1AA from the Fenix Store.
Shipping is the usual fast 3 days to Socal.
My box was slightly crushed during shipping and the clear window showing the light on the box came off but who cares about the box just so long the light wasn't damaged.
Cost $54.28
I won't explain how to use the UI. There is an excellent video by 4sevens explaining the very east UI IMO. You Tube Link. I like this the D10's UI over the Defender's UI. It's more easier to use.
Uses a Cree XRE Q5. My light has a very nice and white beam. The beam has slight ring around the hot spot but not as pronounced as the NiteCore Defender I have.
The D10 can use 1AA Alkalines or Lithium Rechargeable 14500's. My black AW"s Protected 14500 fit with no problems.
The finish is excellent. There is a very slight mis-match of the Type III Hard Anodize between the Lens Bezel Assembly and the Battery Tube. I give the grade A-. The Mis-match of the Type II Hard Anodize does not bother me.
I really like the knurling on the D10, has very good grip. The only drawback is no anti-roll feature.
The fit is excellent. Threads are smooth and the o-rings came lubed.
The rear clickie is on the hard side to push. It 's a Forward Clickie. It uses the Licensed PD Piston System from "McGizmo".
Comes with a lanyard, 2 o-rings, instructions and a Warranty Card.
Uses a Cree XRE Q5.
Rear of the Cree Q5 Module.
Inside view of the Battery Tube.
Rear Forward Clickie. Uses the Licensed PD Piston System from "McGizmo".
Size comparisons.
Left, NiteCore Smart PD D10 1AA. Right, NiteCore Defender 1AA
I also took lux readings of the lights above. These are the lux readings I got. I am using a Meterman LM631 Light Meter measured at 1 meter. I waited 2 minutes before taking the readings. I am using AW's Protected 14500 in both lights.
NiteCore Smart PD D10 1AA 14500 - 2060 lux @ 1 meter
Nitecore Defender Infinity 1AA 14500 - 1960 lux @ 1 meter
NiteCore Smart PD D10 1AA 14500 @ 90"
Nitecore Defender Infinity 1AA 14500 @ 90"
Left, NiteCore Smart PD D10 1AA 14500. Right, Nitecore Defender Infinity 1AA 14500
Left, NiteCore Smart PD D10 1AA 14500. Right, Nitecore Defender Infinity 1AA 14500 Stepped down exposure
NiteCore Smart PD D10 1AA 14500 @ 32'
Nitecore Defender Infinity 1AA 14500 @ 32'
Cost $54.28
Uses a Cree XRE Q5.
Size comparisons.
