Been using my Fenix P3D Q5 as my work light since I got it. I usually work 2nd shift. (4pm - Midnight). Nowadays, it doesn't get dark until almost 2 hours into my shift. The main portion of my security job involves patrolling. I use an electronic wand to hit tiny metal disks, all along my patrol route. The wand keeps an electronic log of all the disks I hit, and the time I hit them. The problem with the detex disks is that they have no adhesive backing. A compound is used to hold them in place. It works well.... most of the time.
The last detex I usually hit, went missing. It's also positioned above a patch of ground that is covered in large pieces of gravel. The color of the detex disk is very close to the color of the gravel. Finding it would be impossible. But I pulled out my P3D, set it on turbo, and tried anyway!
Turbo mode + the nice, bright, hotspot was a big help; despite the Sun still being out. While I never found the detex disk, the light really brought out the details in the gravel. (Found out later that the disk was missing since the weekend, and was likely not in the gravel).
Who says you need darkness to use a flashlight? All you need is a light with a bright enough hotspot! :twothumbs
Anyone else use their lights for a task, while the Sun was still out?
