How will it be a problem? I'd like to hear your thoughts on this.Go ahead then but I don't advise having loose springs anywhere near the battery tube its schoolboy
Yeah, but I don't see how that would happen. You're looking at battery + as you prepare to screw the light head on. You'd see it if a spring were up there.somehow the spring (springs will be springs) gets trapped between the battery tube and the top brass ring it would cause quite a short.
The whole idea is shifty dont you think. He said he wasnt soldering now he's saying he is.
I'm the one offering the most modded pictures here alas I feel I've brought more to the table in the spirit of CPF.
So what about the glass lens oring issue? Are they going to keep breaking with minimal desk dropping or is there a viable fix to address the no play.
OK if you soldered them in its probably a good idea however I like the addition of contact pad and bypass wires myself.
Just looking at Vihns Vn model I'm happy with the standard version but I did notice on the photo on page 14 of his thread that he solders bypass wires to each of the springs for this mod.
Vinh's 6% improvement while doing major overhauling, springs, thermal paste, thermal pads, resistors etc..
http://www.candlepowerforums.com/vb...Best-of-2015&p=4657173&viewfull=1#post4657173
It is not a major thing considering the improvement comes from all the mods, not from the spring mod.
You're right, he said that, but then he had a dream.What did he do with the resistors? He said he could not change anything around bumping the original output up, by messing with originial Meteor driver circuitry. The only thing he's done is improve heatsinking and add bypass wires.
I'm not joking. He had a dream one night of how to do it. VNX2 Goldilocks was born.
He had to get extreme with it, non-reversible mod. It's a bit risky, too!![]()
He hacked a new driver in there, his digital switch newest rev board... VNX2.
Apparently, it's a heck of a lot of work.
