andrewnewman
Greetings:
As the new year approaches I am considering buying a hobby charger and building a battery tray to charge loose (primarily Li-Ion chemistry) cells. I read the thread with great interest where folks with more experience (in both battery charging and woodworking!!) built impressive looking cell trays that are designed to work with a balancing charger.
If I understand correctly, to use one of these chargers you tell it the chemistry, capacity and # of cells in the battery (or tray in this case) and connect up (in addition to the primary charge leads) a series of balancing leads to taps on the (+) terminal of each cell. So my questions are two:
/Andy
- Since the cells are connected in series, I am assuming that the balancing leads need to "know" which cell position they are balancing for (cell's 1 through "n"). Are those little balancing connectors on the side of the charger keyed?
- (This may be charger specific). Most hobby chargers I have seen have connectors for balancing leads for different numbers of cells (2, 3, 4 etc...). If I "tell" my charger that I have 2 cells but I have the balancing leads connected to the connector for the max # of cells supported will things work or do I have to make a separate balancing harness for each of the connector jacks depending upon how many cells I want to charge at any given time?
/Andy
