andrewwynn
i musta pulled 30% outtamabutt.. sometimes best to use a calculator.. i got 20% when i used a calculator which is 'on par' with the 19% you said.. 1000 lumen vs 1200 lumen... i think i must have done the math on one of the 6V bulbs i was using that also used 3.5A.. or even the one that had 5.7A.. in any event.. some were huuged differences.
Wow. that was a swing of numbers. I did my test and measured a 0.16ohm but i was measuring the entire path from the + spring to the - screw tab and shorting out the pr with a piece of metal... that was at 3A (max one side of my power supply will pump out).. the only way to 'really know' is to wire up a tiny test lead to the pins on the bulb and the battery to measure Vbat and Vbulb ... i'm going to be cutting a maglight in half the long way for testing purposes which will make this kind of testing oh so much easier.
-awr
-awr
