mdocod
I'm always on a budget so I like to try to get the most lumens for my dollar, I took a very popular reverse clickie (the Judco IIRC) and figured out a way to mount it up in a hunk of delrin (I ran a thread on the switch assembly awhile back to see if there was any interest in me making a batch of em, never really saw a lot of responses)..
I'm just running a typical off the shelf 50W "spot" (axial filament) MR-16, you can find em in any hardware store, only a couple few bucks each. On 18 eneloops I'm estimating I'm getting ~19V to the bulb, ~100W re-rated wattage, and around 2400 torch lumens... I'll test that Vbulb and Tail current after I charge up the pack again, as I'm curious ... The cells have to be rested for at least an hour otherwise it pops the bulb.
[edit in:]I just measured 21+V at the bulb and 5.75A on fresh cells that had some resting time. Or about 120 watts!!! I'm very surprised at this as I was not expecting to see this kind of Vbulb under this kind of load, eneloops are good, but this must mean that the resistance of the package is quite low. 1.166V per cell after resistance losses under a 5+A load is quite good IMO! With this information in mind, I think it's safe to say It's in the 3000+ torch lumen category
I'm pretty happy with this setup. I've been playing with it on and off for the last few months. The axial filament produces a wall of light that is gradually brighter towards the center. It's a pretty smooth beam with minimal artifacts but the beam quality varies heavily from brand to brand of MR16. The ~100W (50W rated bulb) setup should run for over 15 minutes by my calculations. Dropping in a 20W (driven to ~40W) spot works fine as well and extends runtime to around 45 minutes.
Oh- I ordered a thick High Temp O-ring to help hold the MR-16 down in place a little better. seems to hold up to the heat very well, I've run it for at least 2 minutes straight so far and it does fine, head does get very hot after the first minute
Only problem is I keep busting KD glass lenses from the heat when I do fire starting performances (some of the MR16s I found don't have the built in glass)
