I recieved my lf3xt with aa tube yesterday. Was running fine when I first fired it up.(during the day). When it got dark I was ready to do some comparisons with my RRT-0.
I had both pointed at a white wall inside the house at max. brightness. Kept them both on as I walked towards my backyard, they were both in my left hand(touching eachother). As I approached the back door, the LF3XT went dim.(rough guess, 40 lumens on max, each level was lower than it should be)..... tried new batteries(fresh eneloops, alkaline aa's, and even bought a cr123 for $6 from target), disassembled the light, cleaned the threads/lubed....still the same problem. also, reset to factory defaults.( I've had a lf2xt for 4 months, so, I'm %100 it is not a programming issue that I would have caused)
I have no clue what happened.... all the functions work, but it just isn't as bright as it should be.(like stated, probably 30-40 lumens highest setting, rough guess.) I can look directly into the led at it's new %100 high level.
this may sound crazy, but: could holding both the lights too close together have caused this? they were touching eachother(both lf3xt and jb rrt-0 on MAX.).... I think it was a coincidence, but thought I'd ask.
what is usually the cause of lights functions working properly, but the LED (edit: not) shining at %100?
I already mailed the light back to the seller, and they seem to be doing the right thing. Actually very quick email responses.
