For those that ended up with both of these like myself (due to the loyal following each light has), I am curious to know which light has earned your preference and why. I know that many looking for an EDC are looking at these two lights, and getting some insights of those who have both to compare in actual daily use might be very helpful in making their decision.
So, as it was posed to me recently - If you could keep only your SF L1 or your beloved Novatac, which would it be??
Here are my thoughts...
They are both so different but so perfectly useful at the same time it is very difficult for me to pin down an overall preference.
Ok - my painful choice:
Both lights share the following qualities, so neither would be kept solely because of these factors:
The Surefire L1 is the best by far for use outdoors. It has a huge spot that just goes forever. It will rival some of the bigger lights for spotting objects at a distance, while lighting up a generous area with it's spot. Another thing that helps the L1 outdoors is the warmer tint which I prefer anyway as it helps give me better clarity and depth perception, but a warm tint is especially useful outdoors with the browns, greens, etc.
However, the optic of the L1 which concentrates the beam giving it the excellent throw it has, also severely limits it's side-spill. This is where the Novatac excels. The reason I wanted the Novatac was that while the L1 is great outdoors, and indoors in some cases, it lights up a much smaller area at a very close range due to mainly having a "spot" with little spill. The Novatac can be used at a very close range (indoor type uses) and still light up a very large area.
The Novatac beam is so clean and provides such perfect coverage, it's like you just turned on a light. Also, using a light to look at things closely, you don't want a very strong spot overwhelming the side-spill - you just want the entire area lit. The Novatac has such a seamless spot-to-spill, that it makes it perfect for more close range use such as indoors, or outdoors looking in backyard/shed, etc., but not necessarily hiking in the woods. It is of course easily bright enough for these purposes, but it definitely will not compete with the L1 in that particular area.
One other thing about the Novatac that makes it just so useful is the single-click low/ single-click off. I like the 2-stage pressure switch w/twist for constant on of the L1, but I'm finding the Novatac switch is a little more convenient for everyday use stuff.
So which one would I choose?...........
Well, based on the fact that I'm a big outdoor fanatic, which is one of the reasons I like flashlights so much, I would have to keep the L1. But, if you were to ask me which light I will be using most of the time as a go-to light around the house and endless other tasks, it will be the Novatac hands down.
Boy, I'm glad this is hypothetical because I am not letting go of either one of these lights!
-Rich
[UPDATE]
So this has of course turned out to be a very difficult decision as expected. Even though you have two 1-cell LED pocket lights here, they each have unique advantages and disadvantages due to their very different beam profiles. That being said, many out their that stumble onto CPF will invariably run into this same dilemma trying to decide which one to buy. We will of course continue to stick by the CPF motto "buy both!", but if that isn't feasible maybe some of the opinions here will help. So, without further adieu..
So here's the tally so far (through Post #20):
If I could keep only my SF L1 or my Novatac..
- Solid
- Reliable
- Indestructible
- Excellent UI
- Bright
- Compact
- Versatile
- Clips
-Rich
[UPDATE]
- I'd keep my SureFire L1 - 5
- I'd keep my Novatac - 7
- Sorry, can't/won't choose - 2
