Novice needs help
wicked demon
Hi. I have never really wired anything and a friend showed me some questionable stuff, and I have concerns.
I am making LED strips in parallel. example;
90 bulbs -30 rows of 3 x 3.5v+100ohm resistor
12v 1.5a dc power supply
How do I figure out how much light I am producing?
Is it ok to use any DC converter as long as I use a calculator and the appropriat resister?
If a spec says to use an 82ohm can a 100 be used?
What limits the number of lights you can put in parallel?
I think your going to use 5mm LEDs with the legs right, looks like it will work
Your setting up a 3 Series x 30 Parallel array
+ ___________________
..Res..Res...................Res
..Led...Led...................Led
....|.......|......~repeat~.....|
..Led...Led ....~27x~.... Led
- _I____I______________I
How much current are the LEDs seeing? I figure with the 100ohm resistor on each series of 3 the leds will see 15ma each
Well best to use a switching converter not a transformer coil
Sure but you'll get less current at the LED since the resistor consumes more
A lower resistor would let more current thru but might overdrive your 5mm and burn them out
The amount of current your power supply can deliver
Your setup shouldn't use more than 0.6A
This site may help if you haven't found it already
http://ledcalc.com/
