NYOGEL - now better
teststrips
USA, Pennsylvania
Back a long time ago I had ordered some NyoGel 759G - and used it periodically. I liked it + it kept my threads nice + smooth on my twisties, but when my light sat for more than a few days it would get very hard to move + until it was turned once or twice, lights required two handed operation. I wound up using the radio shack stuff for a long while.
Fast Forward to about a month ago... I attended the FCW-2 camping get together in Pennsylvania... KartRacer had tons of givaways + I wound up with a tube of NyoGel 760G, which was most awesomely sent to KartRacer by batteryJunction - www.batteryjunction.com "remember that coupon code cpf2006 saves you 5%"
I re-lubed a couple of lights + have to say the new mix is awesome. I no longer have trouble with stuck/hard to use threads... so much so that I'm even confident in putting it on clickie lights that hardly ever get opened... I suggest the 760G formula to anyone who used their lights a lot + wants to keep the threads turning nicely.
The 57 gram/2 oune tube is about the size of a medium tooth paste tube (a ton of lube) + should pretty much last you forever... at $6 bucks its hard to beat
I know what you mean ... I found I kept the old 759G confined to the o-rings, and used the radio shack teflon lube for the threads to keep them smooth (especially on twisties).
But the new 760G I also picked up from MattK at batteryjunction is much better, and can be used on the threads. A great improvement, and at a great price.
I got some 760G from lighthound, and it does what your759G did(sticky after a day or 2 without use). seems that the cheaper radio shack lube is better on my twisties:thinking:
Hiya Pumaman,
At what ambient temperature do you store your lights which makes the lube go sticky?
I bought a 500G Jar of 760G from TAI Lubricants, I believe it was $40 + shipping.
760G?
first time I heard of it being "sticky"
used it on just about all my flashlights without ill effects:twothumbs
759G was conductive. Is 760G conductive? I mean passes electricity and enhances conductivity. ProGold, now Dextroit Pro, is conductive, but Nyogel is more of a lub. I stopped using 759G for same reasons, gummed up threads, and lost conductivity.
Bill
From various sites that sell NyoGel 760G:
"NyoGel 760G is not conductive, but it was designed for lubricating surfaces that are conductive".
Is 760G conductive?
760G is not marketed as conductive, but for use with conductive parts... not sure how/why it works, but I've seen no ill effects on brightness even after several months of use. 760G lube has stayed clear + not gotten dirty yet, which is surprizing... most other stuff turns grey/ugly quickly.
I ordered 2 oz of the 760G from Battery Junction to try out. It is made for electrical contacts, not conductive, but must be neutral.
Bill
Hiya Pumaman,
just room temps(68-85F). I realized its worse on my fireflys than other twisties, maybe the o-ring is made of something different than the others:shrug: and its not bad, just a little annoying.
