gunga
It's a press fit bezel. It's possible but not easy.
Its not doing 1.5+ amps for long.
After 90 seconds on high, the S1 drops to 50% (for 1 hour).
Output measurements
As measured from the data 30 seconds into the runtime test below with an Olight 650 mAh 16340 battery, I've estimated the peak intensity of the S1 at 3410 cd, with a beam distance of 117 m. This is compared to 3030 cd and 110 m for the S10R. Both of these measurements are slightly higher than the manufacturer-reported specifications for the S1 :twothumbs:
Runtime graphs
I just measured it, and was getting upwards of 1.8 amps.
1) Whats the best battery for S1 baton?
2) Why do people rave about AW RCR123?
3) Can AW RCR123 be used in S1 baton?
4) Where can i buy AW RCR123?
5) Finally why does AW RCR123 not have the 'A' at the end?
6) also read that AW has discontinued it?
7) Should i just get the Nitecore RCR123A? 2 for $10 on GB. Or 1 Olight RCR123A for $3.95 on battery junction?
LightMagic:
You're asking super newbie questions -- that's good! Everyone was there once, and it's good you're not plunging in without learning a little first. Perhaps the most important thing for you to know is: ICR Li Ion batteries -- that's what we're talking about, when we're saying RCR123 -- are no joke, they are energy dense, and if not treated with respect, they have caused fires and turned flashlights into mini pipe bombs. It's not difficult to learn the proper care and handling, but do head over to the Batteries forum here and do some reading, both on the cells and on chargers. To answer some of your questions:
5) Finally why does AW RCR123 not have the 'A' at the end? When people say CR123A, they are talking about primary (non-rechargeable) lithium batteries. When we say 16340 or RCR123 (no "A" at the end, although Nitecore has taken to putting an A, which I think is a mistake), we are talking about lithium ion secondary (rechargeable) batteries
7) Should i just get the Nitecore RCR123A? 2 for $10 on GB. Or 1 Olight RCR123A for $3.95 on battery junction? AWs were at one time only one of a very few handful of QUALITY li ion batteries, and there's years of good experiences with AWs to back that up. These days, there are many manufacturers of acceptable-quality li ions, and both the Nitecore and Olight seem to have good track records. Most of my 16340s are AW, but I recently bought some Nitecores
Make sure you get yourself a good charger, that has been tested by someone in the CPF batteries forum and uses the proper charging algorithm, including proper charge termination. And mind the safety rules, including: charge li ion batteries in the same room you're in, on a non-flammable surface, and disconnect the charger as soon as the light turns green (or whatever your charger's termination signal is)
Can those with this light recommend a rechargeable cell for it?
I would like to use a protected cell, such as an Olight RCR123, but I saw there was some speculation/observations earlier in this thread that this light's turbo mode exceeds the maximum safe discharge for any rechargeable that's not an IMR. However, IMR's are always unprotected, correct?
I'd love to hear what others are using in theirs and what you'd recommend for me, given that I would like to use a protected cell in mine.
I have the regular S1 and I liked it so much I also just received the titanium version. Man, this Ti version is sweet! Love the neutral beam, the titanium finish is gorgeous, and the copper bezel is a nice touch. Of course, it was nearly 3x what I gave for the regular S1 on group buy, but well worth it to me. I like this exact size for EDC, and I wanted something a little more upscale as far as fit and finish, and had to have a neutral tint now that I've got a SC63w and an Eagletac m30L3c Nichia. I won't go back to cool white!
*Must*ignore*comments*
lol. I love my S1 a lot too (especially for EDC), but always wished it was neutral white. Then I see the comments about the special edition having neutral white options and get sooo tempted!
Edit: Forgot to ask. How do you find the low level and moon light level compared with the cool white. I remember reading something about how neutral white levels may appear (much?) less bright than cool white level. But at higher levels, its pretty close.
1. I agree, neutral and warm ALL THE LIGHTS!1. Neutral white option for base aluminum model(High CRI option would be great too)
2. Better clip design with no pocked snag(preferably screwed on in the preferred bezel down orientation)
3. Easier to push electronic switch that is more recessed to prevent accidental activation
4. Electronic lockout feature like other Olights
5. Voltage readout and/or low voltage warning
6. Memory mode for all modes including Turbo with no stupid 10 minute reset
7. Option for either TIR or reflector/glass lens
