tonywalker23
- Joined
- May 12, 2012
- Messages
- 152
One other thing… the glow in the dark ring on the s10r looks perfect. The gitd ring on the 30 looks more like glowing glitter instead of a perfect ring. Anyone else notice that?
I pre-ordered an S30r from going gear when they were first released and gave it to my dad on Christmas. When I first got the light the battery was low so I put it on the charger and about 4 hours later the green light came on. I use do the light about a day without any trouble and then re-boxed and wrapped it up for Christmas. He has used it everyday now since Christmas and charged it twice. Last night the low battery indicator came on and the light would not come out of low. He put it on the charger and the light immediately turned green but the light still indicated a low battery and stayed in the low mode. He said he wiped off the charger and flashlight contacts as well as the battery contacts but still had the same results. I have not yet measured the battery to see what the voltage is. Do you all think this is a charger related issue or the protection circuit in the battery? He is using an a/c to USB phone charger to power the charger so maybe it doesn't have a high enough voltage and amperage rating. Any help would be appreciated and if I can't get it fixed I will warranty it.
I pre order my S30R few week ago, Got it about 2 week ago, But I see a donut hole in hot spot and very yellowish, take a close up looks at the emitter. It was 2 black dot at the Dom, Call up going gear, they ask me to send it back to exchange it. So I ask can I buy another one first with on sale price of 59.96. and I will return the bad S30R for credit back to my card, Also I request to check the new one before it ship. Got it 2 days later at Christmas eve. Open up the box and charge it full at green light comes on from the charger base. I check the voltage is 4.25V. And the light is perfect . no donut hole and cool white hot spot. I had deal with GG few time. Great customer service.
It's that normal Olight 18650, 3400mah can charge up to 4.25V ?[/QUOTE
Charging to about 4.25 volts appears to be normal. You may have missed my earlier comments on the charger. Using a Samsung 2A USB/AC Adapter, the supplied voltage to the Micro-Dok measured 5.07v and the current was 740mA. When the current dropped to less than 150 mA the charging stopped and the current dropped to zero. I suspect the charger has a CC 750mA/CV 4.2v design with cutoff at 150mA. I checked the battery using a Fluke 289 immediately after charge stopped and it measured 4.2436vDc.
