DocD
this is old news but how do these OSRAM OSTAR emitter 4 or 6 stack up to the P7 did they get to hot or pull to much power? has anyone mod a torch with one? many DocD
I believe it's also less efficient when compared to the P7 as well. :thinking:The Ostar definetly puts out more lumens but does not throw as far.
I already answered in the other Ostar tread, so please let me just type: "do Your homework be4 typing when not informed".Not less efficient, it only draws 1.2 amps max compared to the P7 at around 3.2 max!
I am using the 6 die, putting out between 620 and 1120 lumens at 750 ma. I am unable to ascertain if it is the qz bin or what, but it is comparable to 5 cree q5's (guessing around 1000 lumens at 1.2 amps). I don't have real heat issues with the ostar. The 5 q5's will get too hot to handle after about 5 minutes continuous at 1 amp. In the Ostar, I heatsunk a maxflex2 close to the emitter sink (in a 1 D, it has to be close) and the thermal protection will shut the emitter down to low only in the lowest thermal temp setting at 5 minutes continuous. I set it to the second level and it never shuts down, and the head is not too hot to touch.the 4-die runs on the same current than each of the P7s die but on higher voltage.
data is:
OSTAR (4 die): say 800 mA * 3.7 V * 4 = 11.8 W
P7: 800 * 4 * 3.7 = 11.8 W
very identical power consumption to me
