TORCH_BOY
Cree for me
glockboy said:The Seoul cannot go over 1 amp.
The Cree, I can push it to 2 amp.
Long John said:That's not correct.
All depends on a propper heatsink with a good thermal path, right vf and well constructed configuration.
To overdrive any Led up to 2Amps, I personally have no need for.
When I'll have the use for more light, I'll take my multiple Led-lights.
Best regards
____
Tom
MattK said:SSC for retrofit and lower current lights.
Cree for purpose-built and higher current lights.
IMHO a better way would be to actually make the "ring" a parabolic shape, so that instead of being a vertical ring, it would actually be shaped like a parabolic reflector, and actually aid in projecting light toward the center inherently. Another possibility (probably easier) would just be to spray a frosted coating over it, that way instead of projecting a specualr "image" of the ring, it would project a fuzzy "halo" that would just blend into the spill and probably be more useful.And to think, CREE could probably lose the ring artifact just by making that aluminum ring black. But that would hurt their efficiency numbers.
