Overdriving a MR16 - Voltage drop required, help please
w01fy
Hi all,
Bit of a noob here so some help please.
Have an 18v battery I want to drive a MR16 from, over drive to be precise. As I understand 18v is a little to much and will drastically reduce the life span of the bulb. Also understand pushing 15.6v through it would reduce the life span to 200hours, which I will happily live with.
You ask why! well I want to push the lumens up on the light for just as a play. No real reason. Its been a while since I've done any electrics/electronics so starting with something simple that if I blow up it doesnt matter, then going to slowly work up to playing with some LEDs.
Anyway the help I need is working out the resistance to use to drop the voltage from 18v to 15.6v
Anyway
Power source = 18v
Bulb Power = 45w (Rated 12v)
From the above
45w Halogen @ 12v (Presume I calcualte at 12v not 18v)
P = IV
45 = I x 12
45/12 = 3.75A
So it will draw 3.75A
Now I want to drop from 18v to 15.6v
So
V=IR
V/I = R
2.4/3.75 = R
.64R
So .64R Resistor (seems WAY to small)
Power disapaition on the resisitor
P = VI
P = 2.4 * 3.75 = 9w
So a 0.64R resistor rated at above 9w
My maths I think is lacking here
Can someone give a noob a hand?
Cheers
w01fy
MR16 bulbs can eat 21V direct drive and look amazing.
18 will be fine, just not as bright or white as 21.
Dont worry about bulb life they are cheap $9 for 3 50watters(sometimes on sale at a one dollar for 3) and you can get them everywhere.
I suggest run at 18 until your first bulb goes then decide if you want something weaker.
depending on your battery chemistry, capacity, and the load in amps your lamp will draw, expect the voltage to sag by itself somewhat from 18V. Adding a few volts is fine, if any it'll just burn a little hotter:grin2:
ah cheers chaps! Forget the resisitor then :)
Was my maths correct though or should I be shot at this point?
