I just received my P1D and P1D-CE via USPS. interesting lights, but I will have to live with them for a while before I understand the advantages of each vis-a-vis a Fenix P1 which I also have had several of and still have one left.
The Fenix P1 is more pocketable than either the P1D or P1D-CE which share the same case larger than the P1. The P1 spot is tighter than the P1D. The P1D does give out a bit more light via a broader graduated spot. The center of each spot is about the same brightness.
The P1D-CE on high is definitely brighter than the P1D on high. Yes, I see the slightly darker ring around the center spot. I don't think that it will be noticed in normal use unless you are white-wall hunting.
The strobe effect is certainly disconcerting. I can certainly imagine that the strobe setting will probably attract a lot of attention. I will just skip past it normally. Frankly I could easily dispense with the SOS setting. Way too slow.
However my greatest surprise was trying out different batteries in the P1D and P1D-CE. I tried 3.7v Lighthound/AW and 3.0v Powerizer(same as Tenergy?) rechargeable Li-Ion & primary Lithium in the Duracell, Surefire and Sanyo persuasions.
Using standard fresh primary lithium cells, both lights cycled thru their 3 brightness levels. Using a cell that was about half-discharged, the output from the P1D-CE was dropping noticeably on high.
Using the 3.7v RCR cell, neither the P1D or the P1D-CE changed brightness to any noticeable degree when cycling thru the stages. The output from the P1D-CE was something obviously brighter than a normal "high". The P1D behaved about the same with the 3.7v RCR cell. Clearly the higher 3.7+ voltage is not usable by the electronics - probably go into bypass. The P1D-CE is really bright though!
Only with the 3.0v Powerizer cell did I have the 3 levels available in either light. Looks like I will have to restrict RCR cell usage to the 3.0v Powerizer cells. I suspect that the Tenergy 3.0v cells are the same manufacturer under the case labeling.
run time testing getting started!
Tim
