P3D CE's levels after resting, until Turbo'd
abvidledUK
UK
One of my P3D CE's has a wierd problem.
Sometimes, after resting for a while, perhaps a day or so, when I fire up on the lower settings, it will not go to the higher settings.
What actually happens, is low is fine, if I try to select medium or high, the P3D will switch to that for a fraction of a second, then drop back to low again.
This will continue to happen, until I select Turbo, then back to lower settings, thereafter, all is fine.
It's not the batteries, I've Deoxit'd everything, same wierdness.
Can anyone throw any light on this ?
(It's not a new one, a used one from CPF member)
