Sold/Expired Parallel 3x18650 Megalennium
fivemega
California
(C L O S E D)
3x18650 MEGALENNIUM
NO RESERVATION
FIRST PAY, FIRST SERVE
YOU WON'T BE IN LIST BEFORE YOU PAY
Here is very limited quantity of 3x18650 Megalennium in form of parallel battery connectors.
These 3x18650 body / tail cap for M6 are CNC machined from solid 6061 durable aircraft aluminum alloy with few changes and improvements compare to first run serial 3x18650 Megalenniums.
Mill spec hard anodizing is much more durable, tail side threads are slightly thicker and stronger, tail switch cover is better water resistance and easier to operate.
Body is only 3mm fatter than original M6 but 20mm shorter. Therefore it is eazier to carry and better balance.
Takes 3 protected 18650 connected in parallel for total of 3.7 volt to power up LEDs only.
Do not use any incand such as MN20 or MN21 with this set up.
For 8.4 volt operation, you can install 6 IMR 18350 and all 6 cells positive in first.
No external battery holder required. Integrated battery connectors are installed and come with body.
Body and tail cap involved with a lot of machine work to ensure it will give you same reliability and feeling with original body while you get much more power and longer run time per charge and forget about primary cells.
Tail cap is designed to work with optional McClickie switch and tail cap comes with adapter and black switch cover.
It is possible to use AW's protected 2200 or 2600mAh batteries or IMRs.
Installing your McClickie switch is as easy of installing M*g tail cap. If Gary can do it, you will be easily able to do it in less than a minute or use optional McClickie installed.
Each $129 body comes with parallel battery connectors, front o'ring, double tail orings, tail cap, switch housing ring and switch boot. NO head, NO lamp or socket, NO Batteries and NO charger included.
Each $139 body comes with parallel battery connectors, front o'ring, double tail orings, tail cap, Installed McClickie switch in sleeve and switch boot.
Simply install 3x18650 batteries , M head with proper LED module and ready to go.
Please make sure to install ALL 3 batteries Positive to head side. All battery contacts are marked P as Positive and N as Negative.
NO RESERVATION
please. Payment required before I put you in the list.
For ducumentation purpose, it is necessary to pick next available number, post your CPF handle and detail of your order here and paypal note.
Without above information in paypal note, I will never figure out what the payment is for and from who.
I don't read PMs while I am packaging and I don't package while I am answering PMs.
Example: Mr Liner :paypal: $149 for:
#231 Megalennium plus international shipping.
Price $139 each (cash or CC) with installed McClickie switch (NOT AVAILABLE)
Price $119 each (cash or CC) with installed McClickie switch (MISSING CONNECTOR) (NOT AVAILABLE)
Shipping to States $8 each and add $4 for each body.
Shipping to Canada $8 each and add $6 for each body.
Internationaly $10 for each body and add $6 for each extra body.
Please don't pay unless you plan to make a note in Paypal. I don't need above information in PM. Every paypal must include item name/number and your user name.
Paypal: DO NOT PAY
Please PM for alternate payment method.
Any comment welcome.
Please see:
3 Serial Megalennium-B
2x26500 Megalenniums .
3x26500 Megalenniums .
Shipping within 20 days after full payment received/cleared.
#01 Parallel Megalennium $139 donn_ paid shipped 2308218000002887XXXX
#02 Parallel Megalennium $139 donn_ paid shipped 2308218000002887XXXX
#03 Parallel Megalennium $139 nautilus1950 paid shipped LC547920138US
#04 Parallel Megalennium $139 nailbender paid shipped 2307177000000827XXXX
#05 Parallel Megalennium $139 nailbender paid shipped 2307177000000827XXXX
#06 Parallel Megalennium $139 jslappa paid shipped 0309033000002385XXXX
#07 Parallel Megalennium $139 sprinkle paid shipped 0309033000002385XXXX
#08 Parallel Megalennium $139 Not So Bright paid shipped 0309288000011708XXXX
#09 Parallel Megalennium $139 Red-T paid shipped LC452768284US
#10 Parallel Megalennium $139 fabienne paid shipped LC485383851US
#11 Parallel Megalennium $139 rjr104 paid shipped 03112550000057987566
#12 Parallel Megalennium $139 koala paid shipped LC452889574US
#14 Parallel Megalennium $139 mikesantor paid shipped 03112550000058009267
#15 Parallel Megalennium $139 Congcongke paid shipped LC740353623US + RE785864009US
#16 Parallel Megalennium $139 Congcongke paid shipped LC740353623US + RE785864009US
#17 Parallel Megalennium $139 Congcongke paid shipped LC740353623US + RE785864009US
#18 Parallel Megalennium $139 Congcongke paid shipped LC740353623US + RE785864009US
#19 Parallel Megalennium $139 ming560 paid shipped LC740353711US
#01 Parallel Megalennium $119 (MISSING PLASTIC CONNECTOR) Epsilon paid shipped LC740353760US
(C L O S E D)
This is sale thread only.
Please do not ask questiones about other products in this thread.
Availability, price or any other information about serial 3x18650 is unknown.
Is the McClicky the only switch option?
It is possible to install AW's type B soft start too but for 3.7 volt operation, McClickie is the only option.
Fivemega,
Is this for a body only. No head?
NO head, NO lamp or socket, NO batteries and NO charger included.
Can the tailcap accommodate the switch that was offered with the first run of the 3x18650 serial bodies?
No,
McClickie only. It's easier to get replacement and handles high current very well.
we sooooo need more of these!!
Sorry, no more available or will be. Sorry.
:paypal: (Total $149)
#03 Parallel Megalennium $139 (with installed McClickie switch)
and international shipping (+$10)
I am also interested to find which LED modules members are proposing to use. I know the SST-90s are high draw but are there tower module versions available?
Nailbender makes D36 drop-ins that run off 3~6v in SST-50 and SST-90.:twothumbs
The M3 bezel is D36 as the D36 drop-ins too. I think this is perfect for those who have the D36 SST-50, P7, MC-E, or SST-90 M3 lights.
Oh and what about those who have the M6 LED towers with XR-E, MC-E, ect....
+1 on what would be the possible LAs that we can use with this setup. Can the tailcap accommodate the switch that was offered with the first run of the 3x18650 serial bodies?
:paypal: for #07 Parallel Megalennium + McClickie + Shipping = $147
Thanks for making these... can't wait to get one of the serial ones as well when you have them ready!
Question: Is there going to be some kind of markings on this to differentiate this from the serial bodies are you going to be making?
